LabVIEW Programming
Thank you for your reply. I would like to know the following.
I want to execute a while loop for 5 seconds, and restart after the 5 seconds has passed. Meaning, I want the while loop to restart every 5 seconds. How do i do this in labview?
Also, does labview support any time series segmentation methods such as sliding window algorithm?
Thank you very much
Message 31 of 35
(1,165 Views)
I would advise a timed loop type. This loop will try it's best to run at the set pace.
Ton
My LabVIEW Ideas
Message 32 of 35
(1,160 Views)
Thank you for your reply. By a timed loop, do mean a time delay inside the loop? I do not want the execution of the loop to be delayed. I want a while loop to run for a specified time and restart again. Kindly let me know how I can do this
Thank you very much
Message 33 of 35
(1,159 Views)
Hi teddy_aua,
 can you describe what you try to do please? What do you make in the inner while loop? Maybe one loop with a case structure is enough.
Mike
Message 34 of 35
(1,155 Views)
What do you mean by 'Start again'? A loop runs allways the only thing you can control is the number of runs and the pace of the loop.
Ton
My LabVIEW Ideas
Message 35 of 35
(1,149 Views)
