LabVIEW Programming
  • LabVIEW executes block diagram code based on what programming layout?
  1. Dataflow model, block diagram executes dependent on flow of data.
  2. Top to bottom, program executed starting at the top of the block diagram and moving downward.
  3. Control flow, the sequential order of program elements determines the execution order of a program.
  4. Left to right, program executed starting on the left and moving right on the block diagram.
(3,569 Views)
1
Qestit Systems
Certified-LabVIEW-Developer
(3,553 Views)
Hi ersmt,
that's a CLAD question!
And you should be able to answer all those CLAD questions when you finished those Core1&2 lessons, which are accessable for free…
(3,545 Views)
 Labview follows the dataflow model.
Hope it helps ! 😉
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(3,525 Views)
