LabVIEW Plug-in architecture
I found in LabVIEW User Manual 17-2 saying that:
"Create a plug-in architecture for the application to add functionality to the application after you distribute it to customers. For example, you might have a set of data filtering VIs, all of which take the same parameters. By designing the application to dynamically load these VIs from a plug-in directory, you can ship the application with a partial set of these VIs and make more filtering options available to users by placing the new filtering VIs in the plug-in directory."
Any sample code for doing this? Thanks.
(3,320 Views)
If you have LV7, there's one here:
\Program Files\National Instruments\Labview
7.0\examples\viserver\plugins.llb\Plug In Example.vi
"HermanChan" wrote in message
news:506500000008000000C3CA0000-1079395200000@exchange.ni.com...
> directory."
(3,320 Views)
