LabVIEW PDA...few more clarification required
Hi! Enrique,
Thanks for the links and help you had suggested. It was helpful. I could even find a manual on PDA�here is the link just in case anyone else needs it. http://digital.ni.com/manuals.nsf/websearch/948645EDBFA39E1786256D2C0066B381?OpenDocument&node=132100_US
After reading the manual I have few more questions which are as follows:
1. I could not be very clear as to what execution target should I use when I have to develop a VI for Palm PDA. Do I use Execution target for windows(this si for host PC) or do I develop my application using execution target for Palm Os devices.
2. In my application I have a parameter using which I have to plot waveform graph�.now the manual says that the Digital waveform graphs are n
ot supported on PDA as well as its related VIs and functions. And on Palm OS data acquisition and Instrument I/O features are also not supported. Is there any workaround which can be used for this?
Another point I wanted to clarify was if the toolkit is compatible wit LV6 version or is it compatible with only LV Express?
Thanks once again for all your help.
- AK
(2,950 Views)
Hi AK,
I posted an answer to your question in the LabVIEW general forum. Here's a link to it.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000003BC90000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
Marcus G.
(2,950 Views)
