LabVIEW PDA Module not compatable with LabVIEW 2009
I have LabVIEW PDA Module P/N778596-03 and I would like to use it with my Labview 2009 software.  When I try installing the module LabVIEW tells me that I need LabVIEW 7.0.  How can I upgrade my PDA software or get 2009 to work with this module?
(3,000 Views)
bobster,
Modules must match up with the version of LabVIEW you are running. In your case, you will have to upgrade the PDA module(now known as mobile module) to version 2009.
You can use our Online Upgrade Advisor to get a quick quote using your serial number(not part number) or you can give us a call at (888) 280-7645
(2,980 Views)
