LabVIEW OPC UA support ?
Hello All,
Does anyone know when OPC UA will be supported in DSC and NI OPC servers?
BR,
Jim
(4,610 Views)
LabVIEW supports OPC UA with NI LabVIEW OPC UA APIs https://decibel.ni.com/content/docs/DOC-16930
(4,447 Views)
HI, I'm trying to connect to an Arburg injection moulding machine from Labview 2013. The machine has got an OPC UA server running and is configured with TCP/IP, I've connected using UAExpert but not LV.  NI OPC doesn't seem to detect either the Arburg OPC server or the UAExpert OPC server. Any suggestions on how to resolve this would be welcome.
regards
ER
(4,036 Views)
Did you ever figure out how to communicate with the Arburg using NI OPC UA?  We are running into the same problems.
(3,810 Views)
There was an issue with the Labview driver. I was using an older 2011 version.   It is fixed in the DSC Module 2013.
(3,576 Views)
