LabVIEW OOP - Always pass through object?
Hello!
I'm working on a rather big project right now which involves a quite a lot of LabVIEW OOP. While working with a few of the classes I was wondering what might be the "best" practice to handle the class object for dynamic and static dispatch VIs.
Recently I saw a nice presentation explaining when to pass variables and when not to. Since then I always try to stick to the recommendation to only wire data through an VI if it actually changes the value/ data. I have to admit that this simple rule does make it a lot easier to find the source for data manipulation on a cluster for example if you can skip all the VIs that only use the cluster as an input and not as an output.
So my question is, can I use the same approach for dynamic and static dispatch VIs or is there something special about the whole OOP thing I need to keep in mind when not wiring the class object through the VI?
(1,628 Views)
Accepted by topic author Jens_S
There is nothing special about classes in this regard.  If a method is not updating a class, you do not need to pass it out.
(1,616 Views)
Thanks for you quick response 👍
(1,593 Views)
