LabVIEW - Not Responding
Hello all,
I have an LV Code with a Tree control with custom Menu Items in it. Whenever I right click on the Tree control, I use a "Shortcut Menu Activation?" Filter event to decide which custom Menus have to be displayed. Also when a custom menu is selected from the right-click menu, I do several functions. 6 out of 10 times, when I right click the tree control, or when I select any shortcut menu, LabVIEW does not respond. I have to close the entire LabVIEW application and open it again. I have also differed FP during the right-click. I am completely stuck at this point.
Prasanna.
(3,787 Views)
So are we.  I also have a program that doesn't work -- can you tell me how to fix my program without seeing it?
I'm assuming that the VIs that constitute your program live together in a Folder (possibly with sub-folders).  Compress the folder and attach the resulting .zip file.  Indicate to us (if it isn't obvious) which function is giving you trouble.
If the only problem is "fancy menus" and a fancy User Interface, you could (and possibly should) consider a redesign to simplify things.  Once you get the basic Program to do what it needs to do, you can think about making it Visually Exciting.
(3,757 Views)
