LabVIEW NXG Web server module- Service is unavailable (Link is expiring),VI properties are changing when called Second time.
I am new to LabVIEW NXG, I was trying to build web application using NXG web server module
1. In this process , I tried to load google maps and made some markers on it, successfully able to build it and run it in the browser as well & copied  the same link and used in another application .After building it when i call the google maps link after some time i got error as service is unavailable.
2. I am calling sub VIs in a main VI by changing the vi properties (i.e disabling the close, minimize & maximize) but the properties are changing when it called second time.
(1,409 Views)
As I understand the login pictures are the same. Could you please share more details?
Thank you in advance.
(1,321 Views)
