LabVIEW Logical Shift showing incorrect data
I am trying to shift a decimal number by 16 bits to left, using Logical Shift function in LabVIEW. To cross-check the result, I used an online converter that is showing the correct result. But, the same conversion is not happening with the logical left shift function. Can't figure it out, whats happening. Any idea?
Attached is the screenshot.
(3,351 Views)
Accepted by topic author Voyager7277
Change your Value1 to U32 representation.
aputman
(3,339 Views)
Thanks@aputman!. It worked.
(3,319 Views)
You are using an unsigned 16 bit integer, change that to an unsigned 32 bit integer and you will get the correct result.
mcduff
EDIT: Beaten to an easy solution. 🙂
(3,297 Views)
Thanks @mcduff!.
(3,269 Views)
