LabVIEW Lock in amplifier
hello,
i am using LabVIEW 7.1, and need some help with the Lock in amplifier
start up kit.
i need to know weather the vi will run with a NI card: PCI 6220 'coz i
hav generally seen in relavent documents that it is shown to be working
with a PCI 4472 only....i have not seen any other card also.
according to me it should work fine coz it is only in terms of
resolution that might affect the vi. the rest of the properties seem to
be fine for my needs atleast.
also i was hoping if u could help me with the settings that i should
use in order to lock in at a square wave at a freq of 1 KHz as my
reference. i have the manual but i couldn't understand about the
settings.
Thank u
(3,277 Views)
The Lock-In Amplifier Startup Toolkit can run with non-DSA hardware, but there are several factors (besides resolution) that make DSA hardware more suitable than DAQ for simulating lock-in amplifiers.  DSA boards have simultaneous sampling and the PCI-6220 multiplexes all its channels to one analog-to-digital converter.  The dynamic range on the DSA is much better than on the DAQ devices.  Also our DSA products have built in anti-aliasing filters and the DAQ boards do not. You may need to construct an external anti-aliasing filter to process the signal before acquiring it with the DAQ card.
The Knowledge Base Lock-In Amplifier Startup Toolkit Compatibility with Non-DSA Hardware talks about all of these factors in more detail.
Also let us know which settings you were having difficulty with and we will help you out with that as well.  Thanks!
Best Regards,
Jeff Tipps
(3,246 Views)
