02-06-2025 05:12 PM
Hello. I'm currently performing tests using a Hypot ULTRA 7804 and LabVIEW. I'm planning on doing multi-point tests using two secondary high voltage models SC6540. Using Hypot ULTRA's LabVIEW drivers and library. I found a VI which allows me to configure the scanner (SC6540). I would like to know how can I configure my device to perform automatically 3 IR tests and 6 DCW tests. Thank you in advance for any help.
02-07-2025 01:12 AM
Hi andre,
By creating a "main" VI that calls the needed functions in the correct order! (This is called "programming"…)
