LabVIEW: (Hex 0x6) Generic file I/O error. ========================= I/O operation aborted.
There was no problem when using the instrument before, but the following error occurred recently when capturing the GPIB signal. Now I have downloaded the latest VISA and 488.2, and I have also turned off the antivirus software for testing, but the same error still occurs. How can I solve it?
(1,865 Views)
先前使用儀器時都沒有問題,但最近在抓取GPIB的訊號時卻出現以下錯誤,目前已下載最新的VISA跟488.2,並且也將防毒軟體關閉測試過,但還是會出現同樣的以下錯誤,請問要如何解決呢?
(1,843 Views)
First you need to determine which function is throwing the error.
Then check the values that are being fed into that function.
(1,836 Views)
