LabVIEW FPGA and Xilinx boards & kits
Hi Graziano,
I am having the same ideas as you... I put my 2 cents on that LabVIEW will release such a tool soon and at the moment they are testing in it the academic field.
Kind regards
Message 21 of 50
(9,035 Views)
Hi fpga.be,
   maybe it's just interesting to know if they planned to release commercial products... that'll be a good question I keep for NI week Smiley Happy
   Have a nice day!
graziano
Message 22 of 50
(8,998 Views)
Hi !
I just got this new board and tried to get the samples get running.
But after compilation I get an error 1063
with the hint (I have only the German version so this is a try of a translation from German) like " possible connection not found"
Board is in JTAG Boot mode
Since I am new to Labview it would be great id someone could provide me with some hints
Message 23 of 50
(7,813 Views)
Michael Aivaliotis
VI Shots LLC
Message 24 of 50
(7,709 Views)
Hi parmenides,
Did you install LabVIEW DSP 2.5 after installing LabVIEW FPGA 8.5?  And does error "1063 unidentified error" occur when trying to compile an FPGA VI with elemental I/O? If so, the first suggestion that I have is to try and run a repair on LabVIEW FPGA. If this does not work, then I would suggest contacting NI Support via email or phone in order to troubleshoot this issue a bit further. I hope this helps!
Carla
Message 25 of 50
(7,550 Views)
Many Thanks!
I reinstalled and everything works fine now.
Message 26 of 50
(6,789 Views)
hi!
can anybody explain to me, how i can get access to ethernet interface on my spartan3e starter kit board.
avaible only switches, buttons, leds, lcd, vga, rs232, ps2, dac, adс, strataflash , spi, 1-wire, exp slot.
what's about ddr memory ?
thx!
sorry, my eng so bad (
Message Edited by dsff on 03-30-2008 03:35 PM
Message 27 of 50
(5,508 Views)
@kesakul wrote:
Hello, I need to find out what Xilinx Boards & Kits are directly programmable from LabVIEW FPGA software. I didn't find any consistent information on this topic Smiley Sad
We did not add these lines to the IO because of the stack driver needs. This summer we are updating the driver and could add the line. greg crouch at NI
Message 28 of 50
(5,468 Views)
ok, thanks, i will have been waiting.
Message 29 of 50
(5,454 Views)
i hope you can add ddr-memory and all fx2 pins too...
Message 30 of 50
(5,398 Views)
