LabVIEW FPGA Timeout vs Handshaking
https://www.ni.com/docs/en-US/bundle/labview-fpga-module/page/choosing-between-the-fifo-interface-op... gives the comparison of the Timeout vs Handshaking.  If I can use either and all things are the same to me, is there a preferred approach?  I would lean towards handshaking but would like to get additional feedback on this.
ALE Consultants
(3,127 Views)
Hi, Terry_ALE !
What do you mean by " all things are the same to me "?
In What Does It Do? section of Handshaking says it is used for communication between nodes in high throughput applications
A timeout may increase both; throughput and latency since it has to wait before returning the timeout. On the other hand, this would help you handle unresponsive sections of the code.
So I think you could use Timeout to detect unresponsive elements if throughput is not critical for your application. Otherwise, I would recommend you handshaking. You could decrease throughput even further by implementing pipelining.
Kudos accepted Smiley Wink
Kudos are welcome 😉 marked solutions are awesome!
(3,074 Views)
