LabVIEW FPGA Simulation Mode - maximum amount of DRAM API
My application uses the function: LabVIEW 2015\instr.lib\niIFDig\Memory FIFO\v1\FPGA\DRAM\U512x1\Public\Create Resources.vi
The Host and FPGA code compiles and runs with no problem.
If I try to run it in simulation mode, Windows, that is the LabVIEW FPGA simulation software runs out of memory at this function.
The application needs 1048576 elements.
I worked around this by setting this value at 32768 using a conditional disable structure and I am able to run in simulation mode.
See screen shot below:
I figured this out 'by accident' and some NI people confirmed this is as being a known thing.  Could I get a link to a reference for future use and the training of customer/internal team members?
This is using LabVIEW 2015.  If it is better in newer versions that would be good to know.
ALE Consultants
(2,883 Views)
Hi Terry_Ale:
      Is this VI part of a driver? I have been looking for it or for documentation on it but have had no luck so far.
(2,843 Views)
Can you upload the code?
CLD Using LabVIEW since 2013
(2,836 Views)
This is part of one of the following drivers:
LabVIEW FPGA 2015
NI FlexRIO 15.0
NI RF Device Drivers 2015.11
Thank you for the responses so far.  As it is, I am unable to post the source but I will extract the parts that are causing this to break and share.
ALE Consultants
(2,819 Views)
