LabVIEW FPGA Module Error Code 10 when creating bitfile
I am recieving the following error message when trying to compile a vi:
Internal Error
An internal LabVIEW FPGA Module error occurred at the following stage: Creating Bitfile.
Error Code: 10
Error Text: Create Folder in nirviRecursiveCreateFolder.vi-
>nirviRecursiveOpenFile.vi->nirviWriteBitFileInformation.vi-
>nirviCompileDownload.vi->hardware_template.vi
If this problem persists, please contact National Instruments.
Any help would be appreciated.  I am not very familiar with LabView, and am trying to run code generated by a grad student several summers ago.  If more information is needed, let me know and I will try to provide it.
(4,728 Views)
Hello, look at this link: http://digital.ni.com/public.nsf/websearch/9080C23D9C90BD17862571950072A8E0?OpenDocument Maybe it can help you. Plamen
National Instruments Germany
Application Engineer
(4,708 Views)
Arkolbus-
It sounds like the compiler is having some trouble creating a folder that it needs to generate the bitfile.  First, check all of the usual things: are you an administrator? do you have worte access to the "FPGA Bitfiles" folder in your project?
If it looks like you should be able to write the file, you can try posting your project (zipped) and let someone on the boards try to compile it (be sure to let us know what the versoin is). If we can compile it without issue you may want to try repairing your FPGA module installation.
Xaq "Bulldozer"
(4,625 Views)
