LabVIEW FPGA Basic Connector CLIP and use Strobe Bypass Control
Hello.  I'm attempting to use the NI 6589 Basic Connector Clip.  I've had some success using the Strobe input as a clock by setting the IO_Module_Clock_1_Source = 4. Connector CLIP description here:
http://zone.ni.com/reference/en-XX/help/372614J-01/friohsdio/6589_conn_clipref/
This tells the crosspoint switch to use the strobe input as the clock.  However, I want to use the bypass setting as shown in the users guide (so as not to add any latency into the clock).
If I use the NI 6589 Serdes Channel CLIP it does give me the option to use the bypass setting.  However, I lose the ability to get to the LVDS I/O as discretes and they all become SERDES I/O.
http://zone.ni.com/reference/en-XX/help/372614J-01/friohsdio/6589_serdeschan_clipref/
So the question is... Is there a way to set the crosspoint settings to Strobe Bypass while still using the Basic Connector CLIP?
For reference I'm inputting a 100MHz clock on the strobe, and using that to clock in synchronous data on one of the LVDS inputs.  It is a simple 1:1 clock to bit relationship.  If there's a better way to do this please do tell.  Thanks again.
Message 1 of 1
(2,526 Views)
