11-06-2017 09:16 PM
On some computers this works, on others it does not. I have the following installed on both. There may be something else I need and am missing.
I am trying to configure a FIR Compiler 7.2 on a 7976. Any suggestions?
LabVIEW 2015 SP1f1 http://www.ni.com/download/labview-development-system-2015-sp1/5778/en/
LabVIEW FPGA 2015 SP1 (15.0.1) http://www.ni.com/download/labview-fpga-module-2015-sp1/5884/en/
LabVIEW 2015 FPGA Module Xilinx Tools Vivado 2014.4 http://www.ni.com/download/labview-fpga-module-2015/5492/en/
LabVIEW 2015 SP1 FPGA Module Xilinx Compilation Tool for Vivado 2014.4 f2 Patch http://www.ni.com/download/labview-fpga-module-2015-sp1/6407/en/
NI-FlexRIO 15.5 http://www.ni.com/download/ni-flexrio-15.5/5876/en/
Solved! Go to Solution.
11-06-2017 10:02 PM
Attached is project and screenshot of what comes up
Here I click "Configure Xilinx IP"
And it gets stuck, no Next button.
11-07-2017 03:51 AM
If nothing happens, then something may be running in the background - i.e. a zombie process, and you will probably have to clear out some files in the ip temp directory
If it still does not work, reboot your computer after cleaning up the temporary files.
11-07-2017 07:39 AM
Xilinx IPs configuration doesn't work on Windows 10 - might be the same issue as here: https://forums.ni.com/t5/LabVIEW/LabVIEW-2015-Windows-10-Configure-Xilinx-IP-not-working/m-p/3668520...
11-07-2017 07:50 AM
Link wasn't working -
https://forums.ni.com/ni/board/crawl_message?board.id=170&message.id=1031122
