LabVIEW Error Code -63040
I am running an sbRIO board through a wired LAN and when I attempt to run my FPGA VI I receive error code -63040 which says "A connection could not be established to the specified remote device. Ensure the device is on an accessible over the network, that NI-RIO software is installed, and that the RIO server running and properly configured." Before I setup the network the everything worked fine. I have NI-RIO 3.5.1 installed and MAX says the board is configured.
Any help, ideas or tricks would be much appreciated.
(5,843 Views)
Hi allexy,
If you right-click the sbRIO in your project and select "Connect," do you see the same error?  If you aren't able to do this, but can see the sbRIO in MAX, then it sounds like the IP address may not be correct in your project.  Ensure that it matches the IP address of the sbRIO in MAX and try again.
Jared S.
Applications Engineering
(5,818 Views)
Arg!  Why can't the error description say "verify IP settings."  This solved my issue. 🙂
(5,412 Views)
