LabVIEW Error 200428 with DAQmx Static Task Reference
I'm in the process of updating a LabVIEW application that I've inherited from WinXP to Win7 and LV2012 to LV2017.  We're running with MAX 17.5.
I've a piece of code that adds a number of physical channels to a static DAQmx task and previously this worked but not now.  To dig deeper I tried to verify the task configuration from within LabVIEW and when I run the attached VI I get an error 200428 on the channel property node.  LabVIEW thinks that the task is incorrectly configured but I can't see anything wrong with my definition.
The static task has been imported from the old platform but I've also created an identical task in MAX manually and the problem persists.  Have I missed something obvious?   Any ideas would be appreciated.
SimonC
(2,437 Views)
There is no such error as 200428.  On the other hand, -200428 means something ...
Bob "Know your Signs" Schor
(2,388 Views)
This is why I love forums.....thank you for the constructive observation.
(2,379 Views)
