LabVIEW Driver for DG5101
I have a function generator Rigol DG5101 model and can not find the driver for labview. I just found the driver for 1k and 4k series.
In the link: http://beyondmeasure.rigoltech.com/acton/attachment/1579/f-01be/1/-/-/-/-/file.vi
There is an example that does not work because it lacks VIs (: such as rgdg5k close.vi etc.), is all that I found.
I'd like to supply a driver such as 1k and 4k series if possible.
My interest is to make a frequency sweep as examples of the other series. I would also like if someone can explain me how to use the example called frequency sweep (attached to series drives 1k and 4k) with the generator DG5101.
Regards
(2,632 Views)
