LabVIEW Development on Surface Pro
But to be honest, converting to using auto-tool is something I've thought about over the years, and probably should force myself to be comfortable with.
I always turned it off, first thing, when getting a new version too, until the last upgrade.  At that point, I decided to use it, despite how uncomfortable it was.  But I stuck with it.
Now, I don't notice it at all, until last week, when I had to work on an old LV2009 program.
I fired up the VM which had LV2009 on it, and whoops!  Nothing is automatic. I had to go back to the tab key (it was set the old way).
Both methods are fine when you're used to them, but going back and forth is a real bear.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 11 of 17
(2,005 Views)
I wonder if this is sorta like driving a stick.  You can lean on an automatic or a stick, and you can learn the other method, but if you use one method for too long, going back can take a bit of getting used to.
Message 12 of 17
(1,964 Views)
If you compare the two uses to automatic vs stick shift, I gues I would be using an "auto-stick".  I normally use the auto-select mode, but I switch to manual when I need to do precision stuff, like selecting a control ref instead of activating the dropdown menu.
Bill
CLD
(Mid-Level minion.)
Message 13 of 17
(1,939 Views)
Hint: holding shift forces Select tool in auto mode.
Most annoying in automatic mode is that it sometimes fails when editing control in customize mode (LV2011).
Message 14 of 17
(1,918 Views)
Yeah even with non-auto-tool I have a hard time knowing what tool should be used and usually end up tabbing through all of them one at a time.  Maybe it's because control customization is something that isn't done often.
Message 15 of 17
(1,859 Views)
are there any new experiences with the current Surface devices? I am thinking of getting a Surface Book, and I am curious if anyone uses LabVIEW with the Surface pen. Is it a viable device for LV? How can LV handle the huge screen resolution?
__________________
Engage! using LV2015
Message 16 of 17
(1,701 Views)
Well, I had a Surface Pro (original).  I never used the Pen with LabVIEW (I turned the touch-screen off and used a mouse), and I set the resolution to "half" in each dimension so I didn't need a magnifying glass.  As it happens, I keep my VI Block Diagrams small, so it wasn't a problem ...
Message 17 of 17
(1,694 Views)
