LabVIEW - Dependency Broken - Picture to pixmap.vi Sub VI not supported in current target
Hello everyone,
I had an issue while i was trying to observe the pole-zero-gain equation of several transfer function. I couldn't run my VI due to depency broken error. When i tried to find the root of problem, "Error List" is directing me to the "Picture to Pixmap.vi" and it says "SubVI 'Picture to Pixmap.vi': Sub VI not supported in current target". I am using LabVIEW 2020 version 20.0.0 on cRIO-9057 and i tried both legacy software and standard version. Also, i updated/repaired the labview and crio software but it didn't work. My VI is atteched. Can you help to resolve this? Thanks!
(1,273 Views)
Hi onur_ers
Typically when we see a system executive error arise for a SubVI that has not been changed it is due to a project or library file that has become corrupt. There are a few routes that you can take to fix this issue including reverting to a previous revision of the project or creating a new project and copying your project files over to the new project.
For additional information follow this link.
Regards)
________
Best way to thank is giving Kudos / Marking as a solution.
(1,090 Views)
