‎08-18-2007 07:52 PM
‎08-18-2007 08:23 PM
You will need to provide more information. What is the brand/model of your ethernet IP I/O?
Some possibilities would be a Modbus TCP/IP protocol, or an OPC server/client, or communicating with some sort of driver provided by the manufacturer of the device.
‎08-19-2007 03:44 AM
‎08-19-2007 01:17 PM
‎08-19-2007 11:28 PM
Look at the NI Modbus Library.
There are VI's and examples for how to use Modbus communication over serial ports and ethernet connections.
‎08-20-2007 10:56 PM
‎08-20-2007 10:56 PM - edited ‎08-20-2007 10:56 PM
Message Edited by Duffman Says: on 08-20-2007 10:56 PM
‎09-14-2007 01:52 AM
I've written a set of VIs to perform communication with Allen Bradely PLCs (MicroLogix, Compact Logix, Control Logix) via ethernet. These set of VIs use TCP to read/write tags. No OPC Server, NI-DSC Module nor Automation Runtime is required.
Any Device that supports EtherNET/IP Protocol can ba accessed using these VIs.
I've posted the VIs in LAVA forum.
Please refer to the following topic at LAVA.
http://forums.lavag.org/Industrial-EtherNet-EtherNet-IP-t9041.html
‎09-14-2007 02:45 AM
too bad your vis are password protected ![]()
‎09-14-2007 03:03 AM
