LabVIEW-CMU200 help!
Hi all,
I am a basic programmer using LabVIEW 7.1.
I have a simple project on hand right now, and my project is to remotely configure the CMU200 to make a call.
However, before I could begin, I have to install the CMU200 drivers for LabVIEW right?
So far, I have installed the:
a) CMU200 base drivers - rscmu200_lv7_4_50.exe
b) CMU200 GSM drivers - rscmuk2g_lv7_4_50.exe
c) CMU200 WCDMA drivers - rscmuk6w_lv7_4_50_1.exe
I have copied the (a) Vxipnp\gwinNT\rscmu200 (Win NT) directory to the LabVIEW\instr.lib directory, as well as for (b) GSM drivers and (c) WCDMA drivers.
Now that I have installed these drivers, I would like to try out the application example for WCDMA signalling (rscmu_wcdma_ue_sig_example).
I have downloaded this application example from: http://www.rohde-schwarz.com/WWW/DOWNLOAD.NSF/firstfile/rscmu_wcdma_ue_sig_example_lv6_1_10.zip/$file/rscmu_wcdma_ue_sig_example_lv6_1_10.zip
However, when I loaded the application example, I get this message, saying that they could not find the
rscmuk6w_32.dll
I have tried a lot of ways to find the file but I just could not find it. Please help me! Thank you.
(3,420 Views)
Hi cheng,
The CMU200 drivers that you have are from Rohde & Schwartz, and it sounds like the example is referencing one of the DLLs that should have been installed with the drivers. I would advise that you speak with R&S and let them know you are experiencing this problem, they are probably the ones who can best help you find the DLL.
Rasheel
(3,379 Views)
