LabVIEW BLE (Bluetooth Low Energy) toolkit and Inkbird IBT6X termometer
Hi
I’m working on a LabView program that can read temperature from a Inkbird IBT6X Bluetooth thermometer. (IBBQ)
https://inkbird.shop/products/ibt-6xs
The Inkbird use Bluetooth Low Energy (BLE)
I’m using the LabView BLE toolkit and the BLED112 usb dongle.
I have installed the Bluegiga drivers.
I can connect to the Inkbird and read the name of the device (IBBQ)
I can also change the temperature reading between °C and °F
I can also send the CredentialsMessage {0x21, 0x07, 0x06, 0x05, 0x04, 0x03, 0x02, 0x01, 0xb8, 0x22, 0x00, 0x00, 0x00, 0x00, 0x00} to the characteristic 0xFFF1 on Service 0xFFF0
I can see that it works because the setup keeps the link running afterwards. (Else it will timeout after 30sec)
I can also send the “RealtimeDataEnableMessage”  {0x0B, 0x01, 0x00, 0x00, 0x00, 0x00} to 0xFFF5 on Service 0xFFF0
But my problem is that I don’t get any response (temperature readings)
It seems that I’m missing some kind of subscription state for characteristic FFF4___FFF0
I have tried connecting to the device from an iPhone APP called “BlueSEE”
When I do the same (sending the “CredentialsMessage” and the “RealtimeDataEnableMessage”) and subscribe to FFF4___FFF0 I start receiving data from the temperature probes.
But how do I do this “subscribe” in BLE/ LabView ?
Thanks.
I’m looking forward to get this running so that I can make some great Brisket on my Smoker 😊
BTW
I found some info from others that has it up running but they are not using LabView ☹
e.g. :
https://gist.github.com/uucidl/b9c60b6d36d8080d085a8e3310621d64
https://github.com/sworisbreathing/go-ibbq/blob/master/ibbq.go
(3,726 Views)
Is this question still open? Did you manage to find a way to get it to work with LabVIEW?
Alasdair
(3,470 Views)
Its up running 🙂
/Per
(3,464 Views)
Have you solved the problem?
Could you tell me how you have subscribed to a notify service with the BLE driver?
Thanks very much!!!!
(3,097 Views)
Please have a look at the attached simple demo i made.
Br Per
(3,077 Views)
