01-24-2006 12:27 PM
01-24-2006 12:32 PM
01-24-2006 01:21 PM
01-24-2006 02:10 PM
05-16-2006 12:47 PM
05-17-2006 02:28 PM
Robert,
Have you seen this KB about PDA downloading issues? Make sure that you are not experiencing one of the common issues for running into this problem. Also, what version of LabVIEW are you using? If you are using LabVIEW 8.0, make sure that you have installed the latest patch (8.0.1).
Kind Regards,
05-19-2006 07:12 AM
Still can't get the PDA module to work with a Mobile 5 OS device. It still works great with a Pocket PC 2003 device.
I've tried a Dell Axim 51V and Sprint Audiovox 6700 phone with mobile 5.
I reloaded everything on the machine in this order:
Active Sync, LabVIEW 8.0, the Microsoft embedded tools: C + + 4.0, eVCSP4, and PC 2003 SDK, LabVIEW 8.0 PDA module. In this scenario, the PDA module connects with Pocket PC 2003 but not with Mobile 5.
I than loaded LabVIEW 8.0.1. In this scenario, the PDA module connects with Pocket PC 2003 but not with Mobile 5.
I than loaded LabVIEW PDA module 8.0.1. In this scenario, the PDA module connects with Pocket PC 2003 but not with Mobile 5.
Now according to the NI website info at www.ni.com/info info code pdaevc: Note: Applications you build with the 8.0 PDA Module work on Windows Mobile 5.0 devices
However, according to the info on the same page: You must install the following tools to enable Windows Mobile 5.0 support.
So maybe I'm not interpretting this correctly. Is it that I must load the above components which include Visual Studio in order to CONNECT to a mobile 5 device? In the document it says that apps built with labVIEW 8.0 which utilize the Microsoft embedded visual tools WORK with mobiel 5 devices. They do work, however I haven't been able to download them through LabVIEW and thereby take advantage of the debug feature.
Is there a means of obtaining an evaluation copy of Visual Studio for evaluation if indeed it is required?
Thanks!
05-19-2006 10:53 AM
05-19-2006 12:22 PM
05-19-2006 01:32 PM
