LabVIEW 8.6 with Ubuntu 9.10 - installation troubles
Hi everyone,
I am a new user of Linux LabVIEW - but I am now working on a project which involves it. (I have experience of LabVIEW windows mind you).
 Before we start, I am aware the ubuntu is not a supported distribution - but I only require the software and TCP/IP.
I have ubuntu 9.10 and a disk with a linux labview iso.
My steps
# All down under root (sudo -s, password -->root)
1.  Create new directory and copy iso files (rpms) to hard disk.
2. Convert rpm to deb using sudo alien -k
3. Install deb using sudo dpkg -i
During this step I get file path errors, sometimes permission issues.
One I did this, and I managed to open LabVIEW and run a simple vi. But found that the NI Examples and NI Help were not linked properly. Foolishly, I tried to fix it and then decided to uninstall it all.  It also didnt under when typing ./labview in the terminal nor did linux recognize the .vi format. I had to find .exe to start labview up.
Does anyone have any advice on how I can get this to work?
Does the order matter on installing the debs?
Has anyone tried the install file? I have read that this worked for some .. is that possible? being rpm and debs.
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(5,167 Views)
Hi all,
I tried again and managed it!
1 - mkdir ~/labview
2 - cd ~/labview
3 - cp LABVIEW_INSTALL_MEDIA_MOUNT_POINT/*.rpm
4 - for each of the RPMs run the following command:
rpm2cpio RPM_FILE | cpio -idv
The above command complete unpacks the RPM, after all the RPMs are processed there will be an ~/labview/usr/local/ folder containing all LabVIEW's files.
6 - sudo mv usr/local/* /usr/local/
7 - Just create a launcher that points to /usr/local/natinst/LabVIEW-8.5/labview
However, the example finder and help are not lined. How can I fix these?
Secondly, I still want to know from NI why the Debian install script errored with 1022 permission denied.
Kind Regards
James Hillman
(5,128 Views)
