LabVIEW 8.6 crash on Windows 7 OS
Hi members and LV developers,
I have come across the below crash while running a vi. The program has 2 numerical indicators bound to an OPC server tags, the crash was occuring when I have more than one opc bounded numerical indicator in the while loop(haven't done any further testing). Any comments would be highly appreciated.
Problem signature:
  Problem Event Name:                        APPCRASH
  Application Name:                             LabVIEW.exe
  Application Version:                           8.6.0.4001
  Application Timestamp:                    4862fd60
  Fault Module Name:                          nids.dll
  Fault Module Version:                        4.5.4.49157
  Fault Module Timestamp:                 485a68d1
  Exception Code:                                  80000003
  Exception Offset:                                00054461
  OS Version:                                          6.1.7601.2.1.0.256.48
  Locale ID:                                             3081
  Additional Information 1:                  83d7
  Additional Information 2:                  83d7828a32307d62afcf8149d9e4c374
  Additional Information 3:                  68fd
  Additional Information 4:                  68fd6a10903ecada1d827a617af1d1f4
Thanks.
(3,009 Views)
Accepted by topic author Parny
If you take a look at this link, it seems that NI does not support LV 8.6 on Windows 7.
So if you can, either upgrade LabVIEW or downgrade Windows, you'll save yourself a lot of time.
Hope this helps
Epictetus
Antoine Chalons
(3,006 Views)
Excellent info to sort out.
I never suspected LV 8.6 on Windows7 as the LV 8.6 installation went well on the Windows7 OS and it seems to be Ok with some examples, until I arrived the crash situation yesterday.
Thanks.
(2,991 Views)
