LabVIEW 8.5 shuts down two laptops and displays and error with nimxdfk.dll
I have LabVIEW 8.5 installed on two laptop computers.  While it is running a program, it will shut down giving me a blue screen with a bunch of writing but the important item i believe is it is having problems with the NIMXDFK.DLL and it tell me it is doing a memory dump.  One laptop is brand new with no other versions of LabVIEW installed and one of them has 8.2 on it.  Has anybody else encountered this issue??
(3,505 Views)
Must be in the program you are running. I never had problems on any of the
laptops I've used.
Wiebe.
(3,495 Views)
Hi Chaos,
When you run a simple VI or shipping example, do you experience this behavior? Could you attach a screen shot of the error you receive?
Amanda Howard
Americas Services and Support Recruiting Manager
(3,481 Views)
I've been pulled off on another project but i will try to get a screen shot of the erro as soon as i can.  Can anybody tell me what that .dll file is associated with??
(3,475 Views)
Have you looked at this thread?  It appears to be the same problem you are having.  It sees=ms in this case, the user was creating tasks continually eventually causing the crash.
(3,467 Views)
