LabVIEW 8.5 high-speed camera
I'd like to take many high-speed images with a camera, and save them to a disk, or my computer's hard drive. I congfigure the camera (it is a Pulnix TM-6740cl camera) with the Measurement and Automation Explorer (MAX.) I take the pictures with LabVIEW. I've found an example program in LabVIEW that is close to what I want; it was written by two members of this forum, N_Holmes and reut. The only differences between that program, and the program that I'd like to run is that I need to be able to change the shutter speed of the camera (although I believe that I can do this with MAX), I'd like to be able to change the target directory (for some reason, if I change the directory with the reut program, the camera only takes 1 "frame" and stops), and I'd like to be able to save a file for each frame taken by the camera (I can only get the reut program to save 1 file.) I have LabVIEW version 8.5. If you could help me out in any way, then that would be greatly appreciated. Thanks!
(2,288 Views)
Let's consolidate these threads into one.
Chris Bolin
LabVIEW Partner Program, CLA
(2,264 Views)
