LabVIEW 8.5 Import Shared Library -- does not work
I have been using teh Import Shared Library wizard in Labview 8.2 without any problems. In Labview 8.5 the Import Shared Library wizard does not work.
At the last step, after I click next, it goes to the screen "Generation progress" and nothing happens. Instead of generating the vi it does nothing. I have to press cancel to exit the screen. I checked the Task manager and there is really nothing going on since the labview process has a CPU utilization of 0%.
Did anyone experience this problem???
Like i said before, it was working fine in Labview 8.2 !!!!! ) -:
(3,228 Views)
I have seen this before.  This was reported to R&D (# 4DPEIM5M) for further investigation.  It is very difficult to reproduce and seems to only affect some LabVIEW installations.  Try repairing your LabVIEW installation by going to Control Panel » Add or Remove Programs » National Instruments Software and clicking Change/Remove.  Then select NI LabVIEW 8.5 and click Repair.  This should fix the missing elements of your install and allow the Import Shared Library tool to work for you.
Donovan
(3,213 Views)
