LabVIEW 8.5 Case Structure
LabVIEW 8.5 crashes when I make Duplicate Case structure while Terminal is inside of case.
I have attached an example pdf file
(2,897 Views)
This problem has been reported to R&D - ID 4E29MOP2. The workaround is to check the ""Delete/Copy panel terminals from diagram" option in the Tools>>Options->Block Diagram page.
George M
(2,882 Views)
