08-16-2007 08:37 AM
08-16-2007 03:05 PM
08-17-2007 08:25 AM
08-17-2007 08:30 AM - edited 08-17-2007 08:30 AM
I have an application I wrote in 8.2 (some components saved in 8.2.1), and when I load the project in 8.5, then close it, and select "Save - All", it seems to re-load and run just fine.
Were your original VIs saved in 8.2 or 8.2.1? Do either of you still have a copy of the VIs / classes / project saved in that version (before saving in 8.5)? If so, is there any chance you could post them here, along with what exact steps you're taking to get into this situation? This definitely sounds like a pretty bad problem, any additional information or VIs you can provide would help us determine what might be causing this in your use cases.
Thanks!
Edit: I guess I was too slow, glad you found some information on this. Given the information you found on LAVA I expect the LVOOP developers already know about the issue, but I'll be sure to pass this thread along just in case.
Message Edited by Jeff B on 08-17-2007 08:33 AM
08-17-2007 02:00 PM
