LabVIEW 8.0, Crystal report -> PDF
Has anyone tried developing a crystal report, and calling it in LabVIEW 8.0 via .NET dll so it prints a pdf report similar to printing a standard report?
Kudos are the best way to say thanks 🙂
(4,149 Views)
Hello Maximus,
While I have never tried calling a crystal report .NET assembly (specifically) from LabVIEW, there are numerous examples of calling assemblies both on our website and in the LabVIEW example finder. The LabVIEW Help file is also a good starting point if you've never used .NET in LabVIEW before. From the Help menu, select "Search the LabVIEW Help..." On the Contents tab under "Fundamentals >> Windows Connectivity" you should find a lot of conceptual and step-by-step information. Furthermore, if you can find an example in another programming language that calls the crystal report assembly, you may be able to use that as a guideline for writing your LabVIEW code.
I have seen other posts on the forums pointing to third parties that have developed toolkits for crystal report, but I am not sure if they use the.NET API or not. Hope this helps,
Charlie S.
Visit ni.com/gettingstarted for step-by-step help in setting up your system
(4,132 Views)
Thanks for your reply. I've used .NET to call DLLS. I've not seen a decent example interfacing crystal reports and labview 8.0 so far. Any suggestions ?
(4,129 Views)
Hi Maximus,
I've looked through what resources we have here, but it does not appear that anyone has attempted to call Crystal Reports using a .NET assembly -- in LabVIEW 8.0 or any other version. The best advice I can give is to check out the object model for Crystal Reports (or any other documentation you can find). I found a decent website here:
There's also a link to the SDK documentation:
Since there are currently no LabVIEW examples, you can try piecing one together based on the examples contained in that file. While I (personally) have not done this sort of thing much with .NET, I have been very successful in translating ActiveX to LabVIEW. As I mentioned earlier, there are toolkits out there (built on ActiveX, I believe) that already connect LabVIEW and Crystal Reports.
I hope this helps you out at least a little bit!
Charlie S.
(4,119 Views)
Hi Charlie,
I am looking for an example to create a report and print out using Crystal Reports from a database created using activeX. Where can I find an example. I am relatively new to LabView and just started using it.
e have purchased Report Generation Toolkit, but could not find an example for this. Can you please guide me?
Best Regards
Dintis
Dintis Thomas
(4,083 Views)
Hello Dintis,
I have seen other postings about a 3rd party toolkit using Crystal Reports -- you may want to search for that. LabVIEW used to come with a Crystal Reports shipping example (back in the 6.0 days...). However, I imagine you probably don't have that version! I managed to dig up the old example here, and I've posted it below. I'm afraid I'm not very familiar with Crystal Reports itself. The links I provided on the earlier post may help, though.
Best of luck!
Charlie S.
(4,071 Views)
