LabVIEW 7 Print Documentation Errors
I am trying to print some documentation from my application - all I am selecting the entire hierarcahy (65 VI's) and excluding vi.lib VI's. I am then selecting to print the VI Icon and Description->Descrption only to a plain text file. I have descriptions/header information within each VI but within the text output not all VIs have this information printed. The dropping off doesn't occur at the end by in the middle. I have tried several times and the output varies each time.
Has anyone else had this probelm?
(3,001 Views)
Do all your VIs have documentation and are you getting an error? If so, what is the message? What version of LabVIEW are you using?
(3,000 Views)
Yes all my VI's have documentation (requirement of my compainies quality system). There is no error message - only missing text in the output text file, randomly, i.e. different "runs" have different documentation missing(have also tried with saving to a html file). I am running LV7.
(3,000 Views)
Strongly Agree!  Trying to print documentation and having the same issue.  Random missing documentation when I generate it to a HTML file.  Using 8.0.1
Hope it is fixed in 8.20 because this is driving me crazy ......  Keep hitting generate until it looks correct.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(2,901 Views)
