LabVIEW 7.1.1 Tree Control Memory Problem (Leak?)
I've been using the LabVIEW native tree control to implement an algorithm that uses a tree structure to store data. It works fine, except that I have a lot of data and the tree does not seem to be releasing memory after it is used. I tried everything I could to get the memory released / deallocated but have not found a way. If someone could show me something I'm missing, that would be great. If not, if someone could confirm that they too get the memory leak behavior that I am getting, it would be appreciated.
I am attaching a VI that simply blasts large strings into a tree control so that you can easily see the memory usage going up. The following things have not worked for me to deallocate memory:
  • Delete the tree items, and then close the VI
  • Close the tree reference, and then close the VI (this probably isn't the right thing to do, but I've been trying anything I can to make it work)
  • Explicitly deallocate memory, and then close the VI
The explicit memory deallocation idea came from this thread on a very similar subject, but doesn't work for me.
So either confirmation of the problem or even better, someone telling me how to do things better would be greatly appreciated!
(2,933 Views)
That was horrifying.
The loop iteslf is wrecking the memory. By the time you stop the loop, it's too late, the damage is done. I have 4GB and had to reboot.
First off, put a (huge) delay in the loop!
Richard
(2,905 Views)
That itself is interesting. Maybe the implementation of the tree has changed since 7.1.1 because that loop runs quite slowly on my system (not a slow system) and increases memory usage by about 1MB every second or two.
Sorry about that. I'm attaching another with a delay in it. And thank you for trying it out.
Anybody reading this, put a delay in the loop or use this new attachment!
(2,892 Views)
