LabVIEW 6.1 Bookshelf File Not Found
LabVIEW 6.1 Installation. WIndows 98. Acrobat 4.0. When I click the Bookshelf option in the Help menu, the message box says "Opening manual "D:\LabVIEW61\LabVIEW 6.1\manuals\lvlib.pdf" ... This is the correct path. Acrobat 4.0 opens, then displays error messages "There was an error opening the document. The file does not exist." and "There was an error opening the document. The path does not exist.". However, when I open lvlib.pdf myself directly in Acrobat 4.0, it opens correctly and the index and search functions work fine.
(2,588 Views)
BevP,
Try installing Acrobat Reader 5.0 (latest version). I have also seen this with version 4.0, but I have not had the problem with 5.0.
Randy Hoskin
National Innstruments
http://www.ni.com/ask
(2,588 Views)
