G'Day All,
I have a client that needs some apps written in LabVIEW 5.1.1 built into exe's, but I've found that once I install the App Builder on my Windows XP and 2000 PCs, I get "dist build app image subvi is not executable" - I've tried opening the wiring diagram to fault find, but it is understandably passworded. Has anyone come across this problem, and if so, how do I get around it?
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specif
ically referenced I do not suggest they are necessarily associated with anyone else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
