LabVIEW 32-Bit 2019 Crash when adding NXG Style Decroation
I just wanted to ask if somebody else could try and see if they get the problem I am having below.
With the attached Roll Gauge Control if I remove the existing decoration and try to put a NXG Style Flat Box onto it instead I get a LabVIEW system error and error report and LabVIEW goes bye bye.
If I try doing the same thing on a new VI there is no problem, in face if I try the NXG box on a new control there is no problem.
cheers
Danny
EDIT --
So I have play a little more and it it occurs with other decorations as well. Further more if you create a new control put a simple button on it and save the control plus place it onto a VI the same crash will happen. I am going to upgrade to SP1 and see if still happening
Danny Thomson AshVire Ltd
(2,183 Views)
Hello Danny,
I have LabVIEW 2019 version 19.0f2 (32 bit).
I've tried, and first time I got the issue but after closing and re-opening the issue is gone.
__________________________________________
The best way to thank, is to give KUDOS
(2,030 Views)
