LabVIEW 2026 .NET 8 Interop – Interface Types Replaced with LVBaseRefnum in Generated Assembly (Was Working in 2020)
Environment
  • LabVIEW 2020 (working scenario)
  • LabVIEW 2026 (issue)
  • .NET Framework 4.7 (old)
  • .NET 8 (new)
  • Visual Studio 2022
Background
In LabVIEW 2020, I was able to:
  1. Reference a .NET Framework 4.7 DLL
  2. Use custom interface types (e.g., ICalculator, IProbeAdjusterView) as VI inputs
  3. Build a .NET Interop Assembly from LabVIEW
  4. The generated assembly preserved the same .NET types
Example (LabVIEW 2020 generated method):
public static void Calculations(DataTransferObjects dto, ICalculator calculator)
This worked perfectly — I could pass actual C# objects from my application.
Current Scenario (LabVIEW 2026 + .NET 😎
I upgraded the same concept to .NET 8.
Steps:
  1. Created a .NET 8 class library with:
    • DTO class (DataTransferObjects)
    • Interface (ICalculator)
  2. Referenced this DLL in LabVIEW 2026
  3. Created a VI using these types as inputs
  4. Built a .NET Interop Assembly
Problem
The generated method signature is now:
    NationalInstruments.LabVIEW.Refnums.LVBaseRefnum dto,
    NationalInstruments.LabVIEW.Refnums.LVBaseRefnum calculator)
👉 All custom .NET types are replaced with LVBaseRefnum
Impact
  • I cannot pass my C# objects anymore:
Multiply.Calculations(dto, calculator); // ❌ compile error
  • LabVIEW expects LVBaseRefnum, but:
    • These cannot be created in C#
    • They are LabVIEW-owned references
Attempted Workaround
I tried a dictionary-based mapping approach:
ConcurrentDictionary<LVBaseRefnum, object>
But:
  • I cannot obtain valid LVBaseRefnum instances from C#
  • Mapping cannot be established reliably
Runtime Issue
When trying to invoke the LabVIEW method, I get:
👉 LabVIEW Error 1776
This seems related to:
  • Type mismatch
  • Invalid refnum
  • or .NET 8 interop limitations
Working Minimal Example
C# (.NET 😎
public interface ICalculator
    double Multiply(double a, double b);
public class Calculator : ICalculator
    public double Multiply(double a, double b) => a * b;
public class DataTransferObjects
    public double X { get; set; }
    public double Y { get; set; }
LabVIEW Generated Signature (2026)
public static void Calculations(LVBaseRefnum dto, LVBaseRefnum calculator)
Key Questions
  1. Is this behavior expected in LabVIEW 2026 with .NET 8?
  2. Is there any way to:
    • Preserve original .NET types (like in LabVIEW 2020)?
  3. Can LabVIEW generate interop assemblies that expose .NET 8 interface types?
  4. How are we supposed to pass complex objects (interfaces/DTOs) across this boundary now?
  5. Is LVBaseRefnum the only supported mechanism in .NET 8 interop?
  6. If so, how can we correctly obtain and manage LVBaseRefnum from C#?
Additional Observation
Simple types (e.g., double, string) work fine.
Example:
public static double Multiply(double a, double b)
👉 Works without issues.
Expectation
Looking for:
  • Recommended architecture for LabVIEW 2026 + .NET 8 interop
  • Best practice to replace interface-based design used in .NET Framework
  • Clarification if this is a limitation or a configuration issue
Any guidance or working examples would be highly appreciated.
Thanks in advance!
Message 1 of 1
(167 Views)
