LabVIEW 2019 - Command line for installing Volume License Installer silently
Hello!
Now I have successfully created the Volume License Installer for LabVIEW 2019 with the NI-VLM 3.2.
Which command line I have to use in a batch file to install this on the clients silently?
For LabVIEW2018, I used the following command:
start /wait " " setup.exe /q /acceptlicenses yes /r:n /applySpecFile %Specfilefolder% /disableNotificationCheck
(... where the variable '% Specfilefolder%' refers to the folder 'specfile' with the configuration file 'nisuite.xml')
The configuration file 'nisuite.xml' was created in the Windows Command Processor (cmd.exe) as follows:
setup.exe /acceptlicenses yes /r:n /generateSpecfile "specfile" /disableNotificationCheck
(2,667 Views)
I think with change to deploying by packages for NI Software command-line automation has not been ported/converted/created yet. I have a felling we will need SystemLink to do that previous functionality currently.
(2,591 Views)
