LabVIEW 2018(32bit) connectivity with STM32 via USB
Hi!
I'm using microcontroller (STM32L152RCT) and I want to send commands from LV to the STM32 itself via USB.
Is it possible ? If yes, can you please share a method which should I use, or even better - an example VI ?
Thanks!
(4,283 Views)
@Ragn wrote:
Hi!
Thanks!
I have never used the STM32L152RCT but if it has an on board UART then simply use the proper USB to Serial converter. (3.3V or 5V logic)
In LabVIEW the USB to Serial adaptor will appear as a Com port.
Use VISA to communicate with the STM32L152RCT just like communicating with any other instrument on a Com port.
I am guessing you are also programming the STM32L152RCT0?
That makes it even easier because every aspect is completely under your control, you get to decide on the serial communication protocol, commands, and expected responses.
=== Engineer Ambiguously ===
(4,256 Views)
Hi!
I've chosen to apply different microcontroller, but thank you for replying!
Please, consider this question closed.
Thanks!
(4,219 Views)
Okay,  good luck
FYI: Everything I said above generally holds true for any microcontroller.
(4,211 Views)
