LabVIEW 2016 closes after opening splash screen. Labview 2016 w/ RT & FPGA worked great before NI update. Workaround ?
When I launch LabVIEW 2016, the splash screen shows and then LabVIEW 2016 closes (with no crash report option).   LabVIEW 2016 with RT & FPGA worked great before a NI update, so a patch NI update put on seems to be the culprit.
I tried to repair LabVIEW 2016 32 bit in control panel but this did not help.
MAX still shows LabVIEW 2016 32 bit, as well as RT and FPGA at version 16.0.0
I will live in LabVIEW 2016 64 bit (with unfortunately no support for RT or FPGA) and/or LabVIEW 2015 SP1 32 bit (with RT & FPGA) until a a fix for LabVIEW 2016 32 bit surfaces.
Any and all suggestions on getting LabVEW 2016 with RT & FPGA working again are most welcome and encouraged.
Perhaps there is a way to undo NI update's patch ?  .   I am in Windows 10.
(3,009 Views)
Could you generate a MAX technical report and post it?
Here's an article on how to make one: http://digital.ni.com/public.nsf/allkb/271F252B4EF0A2E0862570E70056A1E4
The MAX technical report should show whether everything got installed properly.  I also suggest trying to completely uninstall and then reinstall LabVIEW 2016 along with RT and FGPA, seeing as the repair didn't work out.
Finally, does this happen on mulitple computers, or just one?  If possible, you could try it out on another computer to see if the behavior is the same.
(2,960 Views)
Also:
  • Did you reboot after the upgrade?
  • Are you running any security software?
  • Anything in the windows system log?
(2,948 Views)
