LabVIEW 2015 not installing, autorun.exe 'encountered an improper argument'
I recently got a new laptop and tried to install labVIEW on it. It started installing, but the system lost power halfway through and shut down. I deleted the National Instruments folder in Program Files (x86) and retried, but when I run autorun.exe it says 'encountered an improper argument' with a red 'X'. So I tried running setup.exe, and it starts, but bypasses LabVIEW and goes on to the real-time module, where it says 'LabVIEW 2015 must be installed before installing the real-time module. Any help would be appreciated.
Message 1 of 14
(6,972 Views)
Is it a problem of improper uninstallation of NI products?
This link seems to be older but might help:
http://forums.ni.com/t5/LabWindows-CVI/Encountered-an-improper-argument/td-p/2383778
Message 2 of 14
(6,967 Views)
 Hi LVKrAkEn,
I already went through that thread and it didn't seem of much use to me, even though they have the same problem. I can't do much in the registry either.
Message 3 of 14
(6,958 Views)
Could you please tell us whether you can see the National Instruments Software in Programs and Features?
Message 4 of 14
(6,936 Views)
If NI Software is shown in Programs and Features, you need to either Remove All or Repair All.  Software cannot simply be "deleted" from your hard drive -- once installation begins, it starts adding things into your system itself (the mysterious "Registry"), and this needs to be "undone" before you can proceed.  An "Uninstall" (or "Remove All") is the simplest and safest way to do this.
Message 5 of 14
(6,929 Views)
I had mentioned in the post that I deleted it (yes, shift+delete) from program files. I did not uninstall as it had been aborted as the laptop shut down.
Message 6 of 14
(6,915 Views)
And did you remove the National Instruments elements from the registry?
(remember to backup registry settings before making any changes!)
HKEY_CURRENT_USER\Software\National Instruments
HKEY_LOCAL_MACHINE\Software\National Instruments
Message 7 of 14
(6,910 Views)
Was I supposed to? And how do I create backup for it?
Message 8 of 14
(6,897 Views)
here is some information on how make registry backups:
https://support.microsoft.com/en-us/kb/322756
If you remove the ones I mentioned above, you remove all the NI registry changes so it can help. You can do it just by running regedit.exe
Here is some general information on how to modify registry entries: http://www.makeuseof.com/tag/what-is-the-windows-registry-editor-and-how-do-i-use-it-makeuseof-expla...
This is not an officially supported way of solving issues with LabVIEW installation, but you can give it a try.
Message 9 of 14
(6,895 Views)
Hi stockson,
Tried that out but no luck, even after rebooting.
Message 10 of 14
(6,887 Views)
