LabVIEW 2015 installation taking too long
I started the LabVIEW 2015 instalation in my laptop (only the LabVIEW 32bits) . It was running normally but stopped at the 72% and stayed there for more than 24 hours. So I started over and now it is stuck in the 0% for over 2 hours.
Is there a way to know if the instalation is or is not working?
I already installed in other 2 computers, and it was normal (few hours to install).
Thanks for advance
Frederico
(2,989 Views)
Hello freddaraujo,
This is known issue and is related to Bank apps on computer, more specific to one of the components of this apps: the Warsaw, which is blocking LabVIEW installation in some other LabVIEW users computers.
César Teixeira
Certified LabVIEW Developer - CLD
Applications Engineering
National Instruments Brazil
(2,941 Views)
It is not sufficient to explain the cause. Do you have a link with details and workarounds? What does the user need to do to successfully install LabVIEW?
(2,935 Views)
Accepted by topic author freddearaujo
Hello altenbach,
To successfully install LabVIEW the Warsaw has to be uninstalled. You can install Warsan again, if you want, but after the NI software installation
César Teixeira
(2,926 Views)
