LabVIEW 2015 Installer goes to 140%
When using the "web-based installer" in a VirtualBox VM, I was happy to finally see the % complete get to 100%.
Then it just kept going. Worried that I would run out of room in the VM, I cancelled the operation.
After resizing the VM, I started the process again. It finally ended around 140%.
This screenshot was from the first attempt:
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(3,927 Views)
This has been seen before (search the forum). I think the answer was that the apparent size shown is what the installer thinks it should be and there is a disconnect between this and what the size actually is.
(3,910 Views)
You went to plaid!!!
Bill
CLD
(Mid-Level minion.)
(3,880 Views)
I have no idea what could have happened but does LabVIEW work after finishing installing?
(3,866 Views)
well you got a lot for you money, be happy! Smiley Very Happy
Epictetus
Antoine Chalons
(3,834 Views)
Maybe the NI installer team are fans of Spinal Tap?
___________________
Try to take over the world!
(3,824 Views)
Matt,
Yes - based on limited testing, it appears to work.
I did not see this issue when installing LV 2012 or LV 2013 in VirtualBox.
This install did have Signal Express which was was not in the other installations.
steve
(3,806 Views)
