LabVIEW 2012 Error 7 when creating executable file
I am attempting to create an executable file to run on a machine without LabVIEW installed on it.  I work through the steps of creating the project and defining the source VI's and build specifications.  When I tell it to build it makes it nearly all of the way through the process but then error 7 occurs when it attempts to save the source VI file.
I have made an executable from this file before with no problems but after altering some code I need to make a new one.  Is it possible that a change in the block diagram is stopping me from being able to create the executable?
Thanks in advance.
(2,951 Views)
Accepted by topic author grabeer
Issue has been resolved.
(2,923 Views)
may be worth mentioning what you did incase others are having similar problems, congrats on solving your problem though
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,919 Views)
