LabVIEW 2010 only installs if DVD drive is D:
My DVD drive letter was F or G and the installer for the LabVIEW 2010 Developer Suite would not run properly.  I believe the error was that a file was missing. I decided to try and make the drive 😧 and it worked after that.
Just though others should know.
Chris Megdanoff
(2,649 Views)
I can't get LabView 2010 to install from drive F.  Is it true that you can only install from D?
(2,580 Views)
LV 2010 was missing from the distribution I was using.  After downloading the missing piece, install from F: went fine.
(2,543 Views)
